Looking for a Scale with Parameters ( SCLP ) in RS Logix 5000 and cannot find ?
Thanks ,
Yes , I downloaded the Add On Instruction , and imported it into the Add On Instruction Folder. I guess Add On Instructions have their own Sub-Routines ? It created a rung with 2- CPT's in them with their destinations being Rate and Output . I thought I would get a SCLP instruction that I could create my tags , min and max , etc.
Do I need to create tags and overwrite the ones in the CPT's ? I'm sorry. I thought it would be " cut and dry "
You can drag the AOI from the sidebar into a normal rung, or find the "Add-On" tab above the ladder editor. What you saw with the 2 CPT instructions was the internal logic of the AOI. Widelto's screenshot shows how the AOI looks when you drop it into a rung.
EDIT: Just for clarification, you would click and drag the "SCP" with the + next to it under the Add-On Instructions in the sidebar in Widelto's screenshot into your ladder.
That's exactly where I want to be , I just can't get there :( . I have a laptop that has full edition . I use the one with RS Logix 5000 Standard , that I take home and use . If I use that , I should be able to create a Sub Routine in Function Block , and be able to use a straight SCLP , and be done with it . I took notice there are 2 different funtion block sub-routines . Which one would I use , or it doesen't matter ? Also , I can still go online with RS Logix 5000- Standard , and still see that Function Block and SCLP ? If not , I can still see the values , correct ?
Thanks again for all your help.
My Goodness . I never dreamed you could drag that over like that. Man , I got so much to learn.
Thanks again,
No problem, I only just learned how to use AOIs myself in the last couple weeks (shame on me, I know). Let us know if you run into any issues and I'm sure someone will know the answer.
Good Morning , I am working on a system that will distribute oil to a mixer in pounds , using a Mettler-Toledo scale , to check the loss of...
1,626
Hello Im looking for a counting scale that has an output that I can send to plc. We are packing 18 parts per box. Weight is about .8 lbs per part...
5,464
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
201
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
144
