Redlion voltage levels to receive data for rs 232 communication
bjrajendra
Jun 2014
36
Hello all,
Actually I am sending a character from my DSP processor to my hmi (REDLION ) with voltage levels +5v and -5v ( I checked my voltage levels using oscilloscope ) and i wrote a program in crimson to receive the character ( using portinput() function ) whatever i send the character with my DSP , the character was not receiving on my REDLION display and nothing it was showing, but the same thing is working with PC whose voltage levels are +10v and -10v and my redlion display is showing the character i send from my hyper terminal . Is there any restriction on voltage level for the REDLION for RS232 communication.
hope someone will solve this problem,
thanks,
B J RAJENDRANATH
I believe Red Lion adheres to the +-3V (minimum) RS-232 specification so the +-5V should be fine.
Since RS-232 is single-ended, are you hooking up the common (ground) pin between the sender (DSP) and receiver (Red Lion)?
I am using a db9 connector on DSP side with rx,tx,gnd pins connecting to rj12 of my HMI for rs232 communication, and I am sure that redlion rx-tx connected to tx-rx of DSP
Attached image of comm pinout just to be sure.
You said Hyperterminal works - with the same cable?
What are the parameters you used for portinput()?
May be something as simple as Hyperterminal supplys a Carriage Return at the end of the string that the Redlion is responding to and the DSP does not.
Parameters:
PortInput(port, start, end, timeout, length)
If you have no leading info to trim set start to 0.
If you are looking for Carriage Return set end to 13.
If no Carriage Return/End character or you want to use a pre-defind string length then set end to 0 and you will need to set the length or timeout to ensure the comm is not sitting waiting for Carriage Return/End Character.
If I know has Carriage Return typically I use PortInput(port#, 0, 13, 0, 80); for string smaller than 80 charachters.
If no Carriage Return I will use PortPrint(port#, 0, 0, 200, Str_length);
Parameters:
I wrote like this
portInput(port#,0,13,1000,1)
ie.,within the time 1000ms it has to receive 1 character it doesnt see 13 as i kept the time and length and i really don't know Carriage Return play a role in this.Is it that much important as I kept the length and time ? and any way my DSP is sending only tx,rx,gnd.
REGARDING CONNECTIONS :
Earlier I had connected like the image shown and my hyperterminal to redlion worked,then i connected only tx,rx,gnd from db9 (HYPERTERMINAL) to rj12 (REDLION) then also it worked.
I had updated to latest version of Crimson 3.0. It had "corrected" a previous issue with the port input function. After updating a G315 with a wireless RS232 barcode scanner, I received no more data from scanner. Called Redlion, and I believe Jeremy verified that this fix actually created a new port input function issue. I had to roll back my version to the next oldest until there is a new update. After rolling back, port input function worked again. This sounds similiar to my problem.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
93
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
157
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
209
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
650
Hello, can anyone help with what driver to use in Crimson to communicate Ethernet/IP to a Prosoft PLX31-EIP-MBS gateway. The gateway will pull...
817
