FactoryTalk View SE V10- System Colors / Global Objects
Tanquen
Jul 2014
CA
163
V 10.00.01
Patch 6
Having a bit of a tiff with View SE.
Ideally there would be a memory tag or parameters file with a color value that could be changed and any object with that tag or symbol would change to that color. So you could have a pump table or set of tags or parameters for the running and fail colors. If you need to use a different green for running or change running to red you just change the tag or parameter and everything using it changing its color. I don’t see a way to even have a variable for any of the objects colors.
While I can’t do that, I can make a Global Object and change the colors latter but it’s a bit of a pain. Like text, I just want to be able to change the text color throughout the application if needed. So I make a global text string object and animate the text color and link that to a memory tag. But… as you can’t just have unlinked Global Object caption text string that you could double click on to get to or search and replace, I now have a “s…s” string in development so alignment is no longer a thing and I have to right click and select Global Object Parameter Values and change the value any time I past a new Global Object string. Once the Global Object Parameter has a value you can search and replace but man, what an ordeal.
The only other way I can see is to not make them Global Objects and animate the colors but then you lose out on the Global Objects global color change. You must know up front and then keep all the colors you started with. Arrghh… :(
Can version 10 and 11 exist on the same computer without a VM Your attention is greatly appreciated Thank you
1,688
Not looking good but I want to simply show part of a string tags value but I see no way to do so a string display or text object. No text or...
4,558
I just upgraded my FTVME to version 10 from version 8.2. Now every time I try to get into my communications setup, it locks up the program. My PC...
3,245
I'm wondering if anyone here is running FactoryTalk View ME version 10 and has tried importing old 32 bit HMI project archive files, say going...
3,555
Anyone know how to change the mouse icon to something else using VBA? It looks like it can be done with VBA forms and based on the object the...
2,213
