plc to led sign
I have used the ViewMarq displays with an ABB AC500 PLC. Had to create some ASCII function blocks, but it worked pretty well. Displaying integers and strings, also changing colors and blinking.
I've done it by writing a basic program on an allen Bradley basic module on a slc500. In my particular case I had to transmit a series of codes to the sign before sending my messages.
I did something like this years back, displayed run speed, downtime, etc.
Used a SLC-500 and a Red Lion LED display.
Seems like the display took a BCD input so I had to convert my integers to BCD and fed plc outputs to control the display, and did some multiplexing to determine which numbers were displayed.....
kinda old school, but that was probably 20 years ago......
regards
JohnR
What is the PLC you are using and what is the display? I have done it many times and most manufactures have several COM's offered, if your PLC offers a ASCII output then that is a easy way but you are limited to distance
Spectrum Controls carries a line of displays call “InView” which used to be made by Allen Bradley. If you’re going to use AB PLC’s (or PAC’s) this is the way to go. Spectrum is a rock solid company so it’s hard to go wrong especially given Spectrum’s relationship with Rockwell (they are very close). The other advantage is you get a lot of options for communications.
http://www.spectrumcontrols.com/InView.htm
http://www.spectrumcontrols.com/pdf...20-02_A0(TECHNICAL_DATA_2706-TD007A-EN-E).pdf
Its doable but not cheap
See this http://www.electronicdisplays.com/database/files/EDI_Profinet_Manual68415468.pdf
They have a Profinet gateway, you would just need to replace the Ethernet switch with a wireless switch
More reading material...
http://wfcs2006.ieiit.cnr.it/indday/siemens.pdf
http://w3.siemens.com/mcms/automati...res_and_benefits/flexibility/pages/iwlan.aspx
I would still try and run a Ethernet cable, I dont like using wireless if you have a lot of electrical noise around and all of my projects did
I have also used http://www.electronicdisplays.com/ and they have very good products
On this project, the operator's asked me to add an LED onto the cabinet of the PLC enclosure, such that the LED illuminates when the PLC's...
1,040
Hi, I have an ABB AC500 PM-582 PLC, The question is... is it possible to get the compiled code out of the CPU, i need to have this as a backup...
1,444
hi everyone i have this simple program using HSC i set the NEW_RV to 1000 when rotating the encoder and when reaching 1000 the counting restart...
1,548
My boss has come up with the idea of renting machines and charging on a per use / per hour basis, so I'm looking into it - just getting my feet...
3,964
Hi In one of our machine, there is Seimens PLC IM151-8 PN/Dp CPU. HMI is connected via Ethernet and other devices are connected via Profibus...
3,107
