Rewriting PLC Program from 6200 series to RSLogix 5000
Melissa
Guest
M
I am rewriting a program from a PLC5-250 to PLC5 using RSLogix 5000 and I am doing some block transfers right now but on the old program I have a .AE, does anyone know the equivalent in ControlLogix?
PLC-5/250 BT control mnemonics
According to the PLC-5/250 Addressing manual, the .AE and .AD mnemonic codes represent Asynchronous Error and Asynchronous Done conditions of a block transfer control element.
http://www.ab.com/manuals/swrsi/5000-6.4.3.pdf
The ControlLogix has .ER and .DN bits in it's MSG control element, so you can directly substitute .ER for .AE
If you're using ControlNet or EtherNet/IP instead of RIO for your field I/O network, the connections and error conditions will be different; BTR and BTW instructions are replaced by Connections.
Thank You
Thank you for the information, it will be very helpful as I am just getting back to that section of the code after going back through the program.
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
18
I know this topic has been brought up a few times, but i had some specific questions. I have installed several 1783-NATR devices and they have...
37
Hello We have installed several G.E. Fanuc 90 70 PLC Everything was ok but suddenly we can not communicate anymore with any PLC with the software...
33
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
51
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
92
