ethernet compact logix
Jan 2013
california
32
Im having issues staying connected to a L35 compact logix controll over ethernet. This plc controls a production line of conveyors. When I connect over Ethernet I can't upload the project from the controller because the connection times out and when i do get online its way to slow to navigate through the program or practically do anything. I've tried both ethernet drivers in rs linx. I just installed rslogix 5000 on this laptop and I have the entire software installed, I'm wondering if that's were the problem is comming from, I'm thinking of unistallin everything and just install the version 16 that I need. There has been other programers that have had no issues staying connected and navigating through the program. I've used task monitor and the Ethernet module on the controller is being hardly used from what I can tell. Any help would be appreciated
I have a CompactLogix 5280 a I am trying to figure out which of the Ethernet ports are A and B. Not finding it in the manual and this is a new...
1,192
Dear all Can any one guide me for mapping in compact logix in RS Logix 5000 which I will be using MOXA MB Gate 5105 for converting Ethernet IP to...
1,545
I have a 1769-L32E Compact Logix processor. I am using the EtherNet port already. I want to know if I can use the serial port to connect to...
1,883
Hello everyone, to get straight to the question, I have done simple programming with digital inputs and outputs but I have never programmed a PLC...
3,531
Hello all! Have an existing 1769-L18ERM-BB1B V28. with full expansion to 8 modules 1--1734-OB8 and 7--1734-IA4. According to IAB this can not be...
1,880
