How to make addressing between AB SLC-500 PLC and Proface GP2300L touchscreen through
vislab
Feb 2005
20
I am now considering to connect a AB SLC-500 PLC and two or three Proface GP2300L HMI touchscreens through Ethernet connection through a Ethernet Hub.
And each each touchscreen has different operator screens and runs a different PLC program separately.
So if this is possible configuration then I wonder how to use address and access each of Proface touchscreen in AB PLC.
If anybody has done similar project or experience then I would like to get some advice or recommendation.
Then thank you and have a good day.
Regards,
Sunny
PLC Connection Manual
There is a manual for connecting GP panels to various PLC's. I think you can download it from the Pro-face homepage - it's at approx 30Mb pdf file. The manual is called "GP-PRO/PB III for Windows Ver. 5.0 PLC Connection Manual". In that both addressing, cable setup and other vital information is found.
I am very new to Modbus and the industry, so forgive me if I am missing something obvious. I have known Modbus register addresses coming from a...
227
I have a system using Rx3I CRU320 redundant CPU with Proficy Machine Edition Software. In the hardware configuration of each CPU module, under...
388
See the screenshot of EIP tag list. We are trying to read in a digital input that is hard-wired. It is shown here as I31.1. I believe we cannot...
282
Hello all. I have a Simatic SM374 (374-sxh01-0aa0) sim module. I am using TIA portal v.18. I can't find this module in my list of hardware devices...
754
Hello, I have a device with 68 words input. But one block on the Devicenet Scanner is only 61 words. I am trying to map this device to 2...
531
