Hi, I'm trying to connect my PC to my plc via ethernet and am having no luck.
SoMachine V4.2
TM251Mese controller with updated firmware.
I am plugged straight into the PLC from my pc via ethernet cable. I have tried both ethernet 1 and 2 on the PLC although I understand ethernet 1 is the preferred connection.
I can login to the PLC via the usb cable just fine. I used that to update the IP and subnet mask of the PLC.
The PLC is set currently fixed.
10.10.19.230
255.255.0.0
no gateway
I have my pc ip address fixed as well.
10.10.19.229
255.255.0.0
no gateway.
I can see the controller from the SoMachine controller screen and even ping it over ethernet, just can't login.
https://ibb.co/iXFDVd
I have tried other ip addresses as well as every subnet mask(255.255.255.0 and 255.0.0.0) on both the PC and PLC. I have my wi fi disabled as well so that only my wired connection is active.
I'm currently out of ideas on what to do. I can't access my drives when connected via USB and want to be able to use a ethernet connection to log in when in the field.
SoMachine V4.2
10.10.19.230
255.255.0.0
no gateway
10.10.19.229
255.255.0.0
no gateway.
