Cheap Software to Program Tablets as HMI's
That is what I do for PLC's not connected to a network with WiFi.
I carry a small WiFi router, I think is cost me about $20.00, and connect it to the switch in the control panel, or directly to the PLC if the Ethernet isn't used, I called the network HMI808 so it wouldn't conflict with any existing WiFi, and connect my table to it.
Plus this allows me to roam around the line wirelessly as long as I stay within the range of the WiFi.
Can you post a link to this WIFI router? I would like to see it as it could be useful in some of my applications
I had a PLC class 7 years ago and I want to relearn it by building my own PLC. I have been collecting modules, CPU, power supply, and rack. The...
17
5,491
;)What are the cheapest and reliable pc based control software and rtu applicable to a process.
1,879
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
61
74
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
775
