samhint
I was looking at the HSC function block in connected components and was stumped by the documentation on how to address the input for the HscID in the APPDATA. It's showing hex but the value is an INT. Then it talks about bits, so just don't want to make an assumption on something here and have an issue with an install. It seems like it's otherwise a straightforward way to program with these modules.
The following is copy and pasted from the documentation:
The HSCApp.HSCID parameter identifies the High-Speed Counter.
The following table lists the values for the HSCID:
Output Selection: First word of HSC Function Data
Bit: 15-13
Module type of HSC:
0x00 - Embedded.
0x01 - Expansion.
0x02 - Plug-in Port.
Bit:12-8
Slot ID of the module:
0x00 - Embedded.
0x01-0x1F - ID of Expansion Module.
0x01-0x05 - ID of Plug-in Port.
Bit: 7-0
HSC ID inside the module:
0x00-0x0F - Embedded.
0x00-0x07 - ID of HSC for Expansion.
0x00-0x07 - ID of HSC for Plug-in Port.
For the initial version of Connected Components Workbench, only IDs 0x00-0x05 are supported.
Thanks for any insight
Bit: 15-13
Module type of HSC:
0x00 - Embedded.
0x01 - Expansion.
Bit:12-8
0x00 - Embedded.
Bit: 7-0
