powerflex 525. Using the Relay 1 contact (R1 & R2) to apply/release brake.
The following worked for me. Please comment if you see issues.
p45=Ramp+EMBrake (want to display my fault codes on HMI -> no CF)
p76=EMBrkCtrl (my motor brake is controlled via Relay1->Contactor)
p86=0.3s
p87=0.3s
p434=1s
p435=1A (motor FLA=2.1A, so 50% is ~1A)
p436=0
p437=Norml RA Res
p438=100
p550=Disabled
After replacing the 70 with the 525, the PLC can read from the drive and recognizes it as online, but no commands are being listened to. PLC is...
551
Good Morning , I would like to start a Powerflex 525 with a N.O. Start Pushbutton , and when the N.O. Start Pushbutton is released I would...
1,656
Hi, I have a potentiometer connected to a siemens micromaster 440 to control a servo motor speed and they are not connected to any PLC. Now, I am...
4,032
Good Morning , I have a quick question about the Powerflex 525 embedded ethernet drive. I'm using a CompactLogix 1769-L18 and using Ethernet...
1,759
Good Morning , I'm building a control panel with PowerFlex 525 drives. I have black wire for the 480 vac , red for 110 vac , blue for 24 vdc...
2,901
