TIA portal V15.1 - VIPA CPU cant get online via profinet
NoName
Sep 2003
Domžale
273
Hello all.
I have trouble getting online with TIA portal V15.1 with a VIPA CPU(VIPA 315-4PN12).
If I try to connect I get an error message that I need to set an additional project-specific IP.
See the attached picture. Has anyone had a similar problem?
Thank you in advanced.
Cheers Aleix
Check the IP address of your computer in Windows. It has to be on the 10.145.65.x network, and not be used by other devices on the network.
Try changing the "Connection to interface/subnet" from "Direct at slot 2 X2" to PN/IE.
Try connecting using an Ethernet cable directly from your computer to the PLC.
I have set another IP in the same IP range and I can ping the PLC from the start.
Now I get an error message that the detected device at the PLC's IP is not compatible... :(
What happens if you go to Online Access in the tree on the left, drill down to your Ethernet card in the computer, Accessible devices, your CPU and go to the Ethernet settings. Post a screen shot of that, if you can get there.
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
438
Hi Folks, Looking for support and ideas. We are trying to go online to monitor/fault find on an S7-300 programmed with TIA Portal V15. I can...
351
Hi everyone i'm trynna install Tia portal v15 The installation starts normale but it suddenly stops asking for a reboot , When i restart the...
32
8,248
Hi I have tia portal professional 15.1 and 16 on VMware , I have an issue where I can’t add a 1500 cpu I can open projects which is using a 1500...
2,585
Could not figure out how to enter AT Overlay. Has Siemens cancelled this feature? Also, how do we create a DB or IDB not by the...
3,754
