Control Logix Real time clock Date and Time tags / address.
Harsha
Dec 2006
Bangalore
Dear All,
I need to read the control logix PLC Real time clock tags / addresses of Date and time to my touch panel. I really appreciate if any one could let me know the tags and addresses for the same. I will waiting for your reply on the same.
Thanking you,
With Best Rgds.
Harsha
Use a Get System Variable (GSV) instruction in the controller to read the WallClockTime object.
Read all about it in the Instruction Set Reference or the Online Help.
Ken,
Thanks for the reply.
Here i dont have the access to the PLC logic. So i dont know whether the customer has used the GSV instruction or not in his logic.
In this case how shoudl i read the Date and time address in the PLC.
Will Wallclocktime(0), WallClocktime(1) etc.. will fetch me the values into my Touch Panel.
Thanks and With Rgds
Harsha.
Is there a way to use LREAL Data type on L71. I am getting 64 bit Double (IEEE754 Double precision 64-bit) data from a modbus device onto PLC via...
952
242
hi all, i have a plc i need to get info from for a site im working on: I have a 1764 Micro Logix 1500 LSP Series C (See Attached Image) im...
373
I currently have a weird issue involving Ethernet IP communication between a ABB CI873 (EthernetIP Module) and a 1756-L83ES. The Layout is as...
745
Possible for two processors in same rack to have separate motion groups across a single Kinetix Rack using a single EN3TR? One 6500/5700 rack, 8...
422
