How to delete an Add-On Instruction (AOI) for a CLx project
BAJ
Jan 2006
Maple Grove, MN
201
Does anyone know how to delete an Add-On Instruction (AOI) from a ControlLogix project? I checked the RA Add-on manual and did a little googling, I'm stumped. The only thing I can think of is an .L5k export, try to find and cut all references, then .L5k import, but that sounds really ugly.
Thank,
-Brad
You need to delete all references as you mentioned. But the AOI can only be deleted offline.
You need to delete not only all the instances of the instruction in the program, but also any Tags that were created, which reference the AOI-specific Data Type.
Just in case it does not work
After clearing all references and linked variables, if delete is still grayed out, reboot the program. Just happened for me on 30.01.00
So in nearly all Ladder Logic software, you can replace an instruction type by right-clicking on it and changing it from a NO to a NC or etc...
2,168
Hi Guys, Has anyone experienced errors while attempting to delete an Add on instruction in RSLogix 5000 V16.00? I have removed all logic...
61
I've got an HMI distributed application for this customer, but we recently changed it (in our office) to a network station because distributed...
8,334
Hello, someone have experience about how to delete an alarm message(alarm already solved) from alarm viewer with something coming from PLC? THANKS
833
381
