Kinetix 6000 E 81 Fault on all drives(16)at once . What could be the cause ?
Rob S.
Sep 2008
Maryland
739
Good Afternoon ,
I have a strange problem with 2 banks of Kinetix 6000 servo drives . The machine is running along for about 10 minutes , and the machine stops and I get E 81 Faults across all the drives , then they reset themselves . Have you guys ever seen this happen and could it be a power issue ? No changes have been made to the machine .
Thanks so much in advance ,
Is this a relatively new installation?
Are the drives on AC incoming power?
E81 is a Common Bus Fault and according to the knowledgebase may be caused by having the wrong setting for "Bus Regulator Configuration" in the drive's properties. This fault will occur if "Bus Regulator Configuration" is set to "Common Bus Follower". For AC power, it should be set to "Shunt Regulator".
1014366 - E81 on a Kinetix 2000/6000/7000
Access Level: TechConnect
Regards,
George
Thanks Sir . This machine and it's Kinetix 6000 units have been the same application for almost 8 years . Yes Sir , I did read that tech note . Could it be power related ? On all the property tags I see nothing related to power .
Hey all, First time poster looking for a little help. I have a Kinetix 6000 drive that I am capturing faults for in RSLogix but I need some help...
950
Good Morning , I have a bank of Kinetix 6000 Drives that I'm getting faults on. I took notice in my ControlLogix , Controller Tags for the...
3,705
Hello all, We have a new customer who had a large A-B servo motor rebuilt and after reinstalling it they are getting a fault on the Kinetix 6000...
5,177
Hi,Guys: we got issue with Kinetix6000 servo drive with E06 (HardOverTravel Fault), I saw "AS_Axis06.PhysicalAxisFault" showing 1 at monitor tag...
1,782
Good Morning , I had a dead battery on a 1756 CPU. Replaced the battery and reloaded the program . Have a Kinetix 6000 that has a E70 fault-...
2,298
