TIA PORTAL v11 - Hardware Catalog update
Roggy
Jun 2011
Czech Republic
Hello,
I am quite new to use this enviroment for programming PLC and I have big problems to find out, how to download hardware updates in this application. In earlier version of STEP 7 there was simple Option > Install Hardware Updates button. But here in this TIA PORTAL v11, everything is a little bit confusing.
If there are any "experienced" guy (well, it's a bit new program, then nobody can be fully experienced), please help... :)
You are right, there are no updates yet. The only possibility is to install GSD file of my missing CPU in the HW catalogue. Do you know, where can I find any older S-300 GSD files, for example: 313-5BE01-0AB0?
Thanks a lot Saperov, I missed those supported HW list files. And also I've been searching for any updates only in english sites, but obviously I should have been searching in German language instead. Thanks, this solves my today's issue. See you.
Hi all, I'm a bit of a noob with Siemens. (I know enough to be dangerous) I've come across a V11 offline program that doesn't match the online...
1,640
Hi, Yesterday I decided to try to download a program to device using my virtual machine which runs Windows 7 Professional and TIA PORTAL V11...
5,537
I am trying to get a tia portal v11 application to run and the software is telling me to install wincc basic v11 update 2 and wincc comfort v11...
4,080
I have a tia portal application programmed in ver 11, but when I try to open the application it says its missing v11 update 2, I downloaded and...
2,770
Hi all and Merry Christmas. I am running TIA Portal V11 with SP2 and UPDP5. I am only running 2 machines with this software right now and...
2,698
