Logix 5000 Add-on Instruction - Fast way to change timer preset values universally?
CJlikesCHAIRS
May 2015
Nope
65
So I have timers in an add-on instruction that work perfect, however I want to change the preset values in all of the instances at once (about 45 instances). Right now, when I change the value in the add-on logic, I need to go to controller tags and change the data type of them (to anything else) then change it back to the correct add-on. Not hard, but annoying to have to explain to the field guys.
Is there a faster way to do this?
You could create a new input parameter in the AOI and move it into the timer preset in the AOI logic.
Then create a PLC tag and assign it to that input parameter for every instance of the AOI. Change the value of the PLC tag to change all of the timer presets.
Good idea, that's great for when I have no idea what the preset might be, and the field guys might have to try a bunch of times. Thanks!
I am trying to add a device to my RSLogix 5000 program. The device is a Eaton PowerXL DG1 I downloaded the eds file from the website (it...
1,753
Can you add a MicroLogix 1400 to the IO Tree in Studio 5000? I can't find an entry for it or anything that is 1762 for that mater. I just want to...
2,310
Hi, need to add stations to a line. Just basically a copy paste situation however I don’t want turn off the line and renown load the entire PLC...
2,482
Im trying to sum a running "Shift Total" production value and move it into a Month Total value that will continuously update for viewing...
1,533
Hello everybody, From user manual "ControlLogix SIL2 System Configuration", SIL2 Add-on Instructions is required to configure SIL 2 PLC...
1,159
