control torque and speed
necyil
Nov 2004
Turkey
102
hello
i am necyil..from Turkey
i would like make a plc program. can u help me?
For Rolling Mill
i need make contro Coiler Torque and speed. I have line speed and coiler speed.
I think for this i need calculate coiler diameter.
May u help me which way i make this
Many thank for your help
Necmettin YILMAZ
I want make control coiler and uncoiler speed with plc. I will use simatic s7.
For this system
I think i must know
-coiler/uncoiler speed
-line speed
i need formula for coiler/uncoiler speed and torque
pls help me
necyil sent me this PM:
hello
is it possible explain me how i control coiler and uncoiler speed and torque (how calculate )
thanks for your help
To necyil,
Please keeep this on the public forum. Other people may come up with better answers to your questions than mine. Other people than just you may benefit from the exchange of ideas.
You said that you know the line speed. Do you know the tension in the material? The formula that I posted allows you to calculate the diameter. Torque is tension (expressed as a force, not as force per unit width) times radius.
I'm doing my first wind/unwind project, and I need some input from someone with more experience. ...I'm getting my butt kicked trying to control...
38
11,274
Hi, We want to buy a linear actuator 24VDC. We want to control this with a circuit board fro electromen...
2,295
We will use a S120 drive for wheight compensation. The drive has to give extra force on a wheigt that is attached to cables. Problem now is, if...
3,755
We have an application where we use a motor with encoder to provide torque at low speeds (+- 5 Hz). The drive is Sinamics G120 in closed loop...
3,255
We wish to use Siemens MM440 in extrusion application, where motor works in torque control mode in one direction and speed control mode in reverse...
5,280
