Any experience with the AB Pico line of controllers?
Sep 2018
Chattanooga
68
I wrote a small program the other day (4 inputs, 5 outputs) for a piece of equipment we have. A simple shackle bender with 2 limits, a footswitch, a 3 position hydraulic valve and a 2 position pneumatic valve. I wanted to add some jog controls into the program so I put a NO (momentary on-off-on 800T) and a NC (limit switch) in series with each of the hydraulic coils. However, when I put it into simulation in PicoSoft, because I had already used that address for the coil previously in the automatic mode it wouldn’t allow the automatic mode to run, just the jog. When I removed the line with the jog instructions, it functioned as it should. Am I missing something? Is this a limitation of the Pico’s? I know this line was discontinued and we have several in the stock room. I was planning on upgrading a lot of the smaller skids we have with these and remove a lot of the relay logic that is still hanging around. They’re are neat and simple controllers but I hope I am overlooking something.
It is a 1760-L18AWA Series B
Nevermind, I may have figure it out scanning through the manual. I guess it needs an add’l letter differentiating the two outputs (but the same mechanical function). Ie ( Q4 ) and ( RQ4 )
@ All: what is your best guess on a potential range in increase in efficiency in % (i.e. saved programming hours, greater output, etc.) when...
349
Hey guys, has anyone worked with any type of Keyence PLC and could share their experience with it? Vendor showed me camera footage reply of a work...
1,162
Hi, I have a customer inquiring about an automation product called uSwitch. I can read all the literature but working experience is always...
605
Hi to all, does anyone have experience with using Codesys software for PLC programming? (https://www.codesys.us/) What I can find out is that...
1,116
Hi all, I am experienced with Rockwell by have recently encountered a Bosch PLC. It’s an IndraControls XM21 V14. I installed the software and...
773
