Communication problem between CompactLogix and SCADA
Johnpath
Jul 2010
Montreal
Here’s the problem I have :
I have 3 SCADA (PC) communicating with 4 PLC (all CompactLogix).
One of the SCADA can’t establish communication with one of the PLC.
It will respond to a ping request for the 3 other PLC.
At the beginning, we had an IP address conflict between the problematic PLC and PC. I’ve changed the PLC IP address.
So now, I can establish communication with that PLC and my own computer and the 2 other SCADA. But the one that had the same IP address still does not reply to a ping request, or the SCADA can’t see any TAG of that PLC only.
We also tried to switch cable and connection from one SCADA that works, and still had the same problem.
In the PLC, on the Port Configuration Tab, I entered :
- New IP address
- Same Subnet as before
- Same Gateway
And I’ve checked : Auto-Negociate Port Speed and Duplex.
Is there something else I should be looking for on the PLC side, after changing the IP address?
Thanks for your help!
Hi experts, I have Panelview 800 Teriminal (version 4.012) connected to 5370 compactlogix L2 controller(1769-L24ER-QBFC1B). Through Ethernet...
16,345
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,604
I need some help. I have established communication between the Modicon Premium PLC, using PL7 Pro ver 4.5 software and Adam 6251 remote I/O...
3,810
This Problem happened many times, is it only because the wrong type DB10Q0 should be DB1010 or any other possible cause? HMI log file ...
8,538
Hello, I got 2 S7-200 communicating with each other and a computer with Simatic Softnet Lean 2006 communicating with both PLC. When...
1,439
