About the 1769-HSC fault
zhoudq
Jul 2011
JiangSu Province
75
Hello everyone
I have a project used the 1769-HSC module, the module install the 7 slot. I confige the module, as the module power on, the module OK is flishing red, I check the program,find the local:7:I.fault all the bits are set 1, but I don't cleaning the fault and i don't find the error code, the datum isn't the fault introduce, so please help me find where the fault or where find the error code in the program,thank you.the attachment are alarm pictures.
hello gclshortt:
Thank you , I have the datum of the 1769-HSC module and i know the datum of page 117 are error codes and error extended information code, but i don't see the error code in the program, so i don't know where the fault configue of the module, please direction me find the error code in the program, thanks look forward your reply.
Hello all. I am having trouble setting up my HSC to count pulses from a prox switch. I have it wired to the prox and I see the .InputStateA0...
1,369
Here is my hail Mary pass I have a wheel that produces 33 pulses per revolution. The RPM of that wheel will be anywhere from 25.21 to 62.7 Pulses...
4,699
Hello all. I have an issue that keeps plaguing me. The system has a 1769-L24ER processor and a 1769 HSC card. I am using CH.0 for tracking...
1,466
Hello, Im trying to use a 1769 HSC card to get the RPM of a single channel encoder at 60ppr. Ive read the other threads of people have similar...
1,694
Flashing Red OK Status indicator : Rockwell Automation Publication 1769-UM006E-EN-P - July 2013 Table 23 - Configuration Error Codes pg 117...
2,177
