Remotely Automating PLC tasks by changing tags over WLAN
paseka
Aug 2005
Johannesburg
We are building a small plant that packs beverage cans from a conveyor belt to a crate in responce to an order.I have been assigned a task to write an application for a Pocket PC(in Java)to enable a user to make orders remotely on a WLAN.I thought I would tackle this by writting code on the PDA that will insert a record like "insert into Ordertable values('numberofcocacolas','numberofpepsis')".A script in wincc would then read the entered record and update the PLC(s7-200) tags.Is this the best way?
Is it possible to directly reach the tags and change them over the WLAN?
Is it allowable for me to build my own table in SQL Server(Wincc) or this only for system purposes?How do I write a VB or C script with SQL statements?
Thank you
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
91
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
322
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
208
I've asked this before but I still couldn't make it work. I just can't envision a solution. Local RTU has a screen to set a handful of...
18
1,548
Hi guys, I'm a beginner in this field, but i have knowledge on IT i want to give a help to my best friend for his SIMATIC Microbox PC that he...
1,094
