CompactLogix IP Address
FSPT_Tech
Jan 2007
Compton, CA
42
I'm trying to find out what the IP address is on a CompactLogix processor. The processor is the "mother" control to other equipment that are on the same network. The other equipment are using Micrologix processors. I have a copy of RSLogix 500 which enables me to go online with the other equipment and see their IP addresses. But I can't go online with the mother's CompactLogix processor without using RSLogix 5000 software (which I don't have) to see the programmed IP address. Is there any way to find out what the IP address is on this CompactLogix processor? The external equipment is not yet linked to "mother". We are still running cable for this. I'd like to know how to find the IP address of the mother's processor without going online if it's possible.
Is there any other way?
Thanks.
You can use RSLinx with an Ethernet/IP driver to find it. It should show up (if connected) as a CompactLogix processor with the IP address next to it.
Paul
The Ethernet/IP driver will return all Ethernet/IP nodes in your subnet. The Ethernet Devices driver requires you to manually enter each IP address.
OG
I have my PLC and HMI connected to my local network over DHCP just like my laptop. I can upload and download including VNC to the HMI over wifi...
1,137
Hi Guys, I'm trying to get the IP address of my L33ER Compactlogix to show up on my PV+ 600. I know about answer 26779 and have tried it but I...
17
2,733
I'm trying to configure the IP address of my compactlogix l16er-bb1b in Studio 5000. I need to set it to a certain address as I'm planning on...
3,221
Hi, I have a compactlogix 5069-L330ERM processor, which has 2 built in ethernet ports. Both are currently configured and was completed using...
20
8,908
We have some vendor supplied machinery that runs on a CompactLogix 5370 (1769-L24ER-EBFC1B, FW rev. 28.011) that wasn't communicating with the...
2,920
