Hello All,
Not sure if a network question is appropriate here...sorry if not.
I am having an issue with connectivity between multiple devices connected to a managed switch.
I have:
1. Managed Switch 192.168.110.5
2. PLC - Micrologics 1500 192.168.110.10
3. HMI - Red lion Graphite 192.168.110.15
4 HMI - Red lion Graphite 192.168.110.20
When I plug all the above devices into the switch I have no problem communicating thru the switch to each device. I can ping each device from my pc which is also on the same network listed above.
I have another PLC with a network address of 192.168.36.100 which I know is not on the same network as the other devices. When I plug that into the switch it actually fubars the switch somehow. My understanding is the the switch does not care about network addresses and plugging multiple networks into the same switch should have no effect. This is a level 2 switch.
The functionality of all the devices below the switch still works...plcs and hmis on the same network can communicate...the hmi's can pull and push data to the plc.
But whats weird is I can not connect to the switch or thru the switch to devices from my pc...cannot ping the devices.
That does not seem right...when I pull the odd ball network plug from the switch everything goes back to normal. I can then ping each device again.
any thoughts or ideas on why this may happen?
Any help is greatly appreciated
I have:
