Cattron Safe-E-Stop to Controllogix L72 via Ethernet/IP
Jasondelane
Mar 2015
Florence sc
220
I've purchased a Cattron Safe-E-Stop for use with a conveyor system. I've figured out all the configuration and wiring except for the ethernet/ip portion.
How would I configure a 1756-L72 to receive the E/IP data from the Safe-E-Stop?
I've attached a PDF containing the Safe-E-Stop Ethernet/IP data mapping.
Update. Received this from shipping department at 3pm. Installed and communicating by 4pm.
This setup worked perfectly, thank you.
Can somebody share the AutroSafe configuration Tool C4.11.4 Thank you
72
I have a GuardLogix PLC with safety inputs of HMI, Estops, Light Curtains, and Gates. Is it considered safe for the safety program to monitor the...
736
We have an existing VSD where a three phase circuit breaker feeds the drive, and two phases also tee off to a contactor, which is energised to...
1,455
Hi, I'm trying to understand a couple of things with a feedback signals that are used in a SRP/CS that I'm working with. Quick disclaimer: I'm...
492
