Slc 150
Nick.Ferguson
Sep 2011
Nebraska
24
I have some SLC 150 still running in my plant and have been asked if I can back up all programs ( which is done twice) and document. The problem I am having is the program i have is "SLC Logistics Revision 2.09" and I am running it with dosbox. My problems is I do not know how to configurator for an old style printer. Is there some where I can find a manual on this program and/or is there a way to configur for a USB style printer.The Program Header is SLCU
Try this link, they have a free trial version.
Link:
http://www.printfil.com/english.htm
Link to SLC 100/150 manual (Large file, approx. 17meg's), Right Click,> Save As
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1745-um001_-en-p.pdf
Links to a great site for more info:
http://www.plctrainer.net/DOSBOX.pdf
http://www.ind-concepts.com/
PS. Many threads on this site. Use keyword slc100 in the Advanced SearchBox.
I have slowdos.exe and slowdos.bat files that will help with the configuring if you need it.
Hi Nick. I’m not familiar with SLC Logistics Revision 2.09. I do have PSIC. This is the program that I used to program the SLC 150’s that I have in the plant. This program runs in DOS only. When I want a print out the program, I send the program to a file. Then into WordPad where I can print to any printer on the network. Where it asked for the printer I can put the name of a file. You might have to do some editing
Hope this is some help. If you need more info feel free to ask.
Pat
PCIS was the old Allen-Bradley software for the SLC-100 and SLC-150 controllers.
SLC Ladder Logistics, aka "AI-100/150", was made by ICOM, Inc.
I've always had these old programs print to a "serial printer", then capture that serial output with either a virtual serial port or sometimes a physical serial port. The data just dumps into Hyperterminal or Tera Term and I save it as a *.TXT file for cleanup and printout.
Ken that is a slick idea I never thought about using the serial print and capture idea. Thanks
How can I get a schematic for it? I am unable to communicate to it using PCIS with a 486 PC and suspect the SLC150 to be faulty (found in a junk...
3,082
HELP! I've been searching & searching for the software to run my SLC150 PLC for DOS 6.22 and for some reason, every link I have found for it -...
1,149
Hi, I have an old SLC 150 processor that is throwing up a CPU Fault light. I have an EEprom program chip for it, but I can't get it to load up...
2,314
We have 3 SLC-150s that we are using, we would like to create a print for them and diagram the program so when we get approval we can replace them...
2,640
Hello, I am completely new to PLC's (and forums) and have been tasked to repair/upgrade a conveyor system at my college. It currently has an Allen...
2,683
