![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Ethernet to RS485 ASCII
I need an adapter for Ethernet to RS485 ASCII traffic.
I found a couple cheapos and bought them but all the docs were in Chinese and I just can't install these on anything important. Is there a trusted brand that uses a Serial-to-Ethernet driver on a Windows Server OS (on a Virtual Machine ) to connect to the device, which then can talk to the RS485 network as if it were a local port on the Windows Server? These things are everywhere if I'm using USB but with a VM I have no USB port to connect to so I need an ethernet connected device.
__________________
. . .Nostalgia used to be so much better . . . |
#2 |
#3 |
![]() ![]() Join Date: Oct 2008
Have used them for years I actually just carry a 8 port unit with me for any type of serial connection I may come across never had any issues.
https://ww2.systech.com/nds-family Also digi used them https://www.digi.com/products/networ...l-connectivity
__________________
" Nothing is impossible , all it takes is TIME and MONEY" HT |
#4 |
![]() ![]() Join Date: Jan 2006
Moxa Nport range should work.
On PC side you install Moxa virtual com port driver which directs packets to TCP port and then to moxa Nport's Com port. If you can use TCP directly, then driver isn't even needed. |
#5 |
Thanks folks - I'll start poking around at these. They seem to be more common than I thought. LanTronic has some too now that google has seen what I am looking for
__________________
#6 | |
Quote:
Moxa has worked pretty well without need of rebooting of converter. Moxa calls com rerouting to Real Com https://www.moxa.com.cn/getmedia/4ce...-note-v1.1.pdf Thought there is 6-7 different modes to select on Moxa. |
#7 |
![]() ![]() Join Date: Apr 2021
I have used lantronix for years. We have hundreds of them out in the field and they just won't die (I sometimes wish they would so I would have an excuse to upgrade them)
#8 |
![]() ![]() Join Date: Feb 2012
Have a half dozen Moxa NPorts running virtual com ports over cellular VPN to a server on a VM. These poke serial data out into master radios at remote repeater sites. They have been very reliable despite the less than optimal ethernet network path.
The moxas have both RS485 and RS232 ports available. |
#9 |
I bought a Lantronix one. I actually saw those earlier but didn't read what they did correctly, thought they were like a Short Haul modem.
__________________
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
KEPware Allen-Bradley Controllogix Ethernet - How to Read ASCII file | Tanquen | LIVE PLC Questions And Answers | 4 | May 5th, 2022 11:51 PM |
Ethernet solution required | Spanner_zn | LIVE PLC Questions And Answers | 5 | June 3rd, 2015 11:22 AM |
How to MVI56-GEC Ascii Ethernet | jhuan011 | LIVE PLC Questions And Answers | 1 | September 20th, 2014 02:24 PM |
ascii ethernet data to RSView32 | sidhu | LIVE PLC Questions And Answers | 0 | August 26th, 2009 01:18 PM |
Ascii string over Ethernet in CLX | Contr_Conn | LIVE PLC Questions And Answers | 2 | June 17th, 2004 10:07 PM |
