![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() ![]() Join Date: Feb 2010
PLC Ethernet/IP Network Layout Suggestions
Hello, folks.
Looking for suggestions on network layout. I'm designing 3 stations with 6 pieces of conveyor on each. They are part of the same system so will share a PLC. Thinking this way. Station: #1. PLC, Local IO, 6x VFDs #2. Remote IO, 6x VFDs #3. Remote IO, 6x VFDs RemoteIO is for sensors and buttons. VFDs are for the conveyor motors. I think I'm gonna go with Rockwell - ControlLogix, PointIO, and PowerFlex525. Problem(-ish): The stations are not very close to each other. So in order for all to communicate, I'd need to install an Ethernet switch at station #1 and then run 7 Ethernet cables (PointIO + 6x VFDs) to station #2 and 7 Ethernet cables (PointIO + 6x VFDs) to station #3. Could anybody please suggest a more elegant solution? Thanks in advance. |
#2 |
![]() ![]() Join Date: Nov 2016
fibers between PLC and remote IO, a dedicated switch on each to distribute from fiber to ethernet on a DLR configuration.
#3 |
![]() ![]() Join Date: Feb 2015
The 6x VFDs and remote IO in #2, how far are they from each other? Same for the #3?
If these devices support two Ethernet ports and they are Rockwell devices, the device is itself a switch so you can daisy chain them. But if the LAN cable needs to be longer than 100 mts you will need to put some switch in between. Also, is any of these segments going outise the building? In this case some fiber optic converter would be a good advice to protect against lighting? I think we need more details in terms of which kind of EtherNet/IP devices, whether they are industrial grade, distances, etc., so that more meaningful advice can be provided. |
#4 |
#1.
Switch with Fiber interface Ethernet cable for PLC, Local IO and 6x VFDs | Fiber | #2. Switch with Fiber interface Ethernet cable for Remote IO and 6x VFDs | Fiber | #3. Switch with Fiber interface Ethernet cable for Remote IO and 6x VFDs | Fiber - return to #1. for ring connection (separate cable) Switch https://www.moxa.com/en/products/ind...ds-516a-series Safe and solid solution �� Last edited by JERA; January 20th, 2023 at 11:59 AM. |
#5 | |
Quote:
#6 |
Fiber isn't necessarily required. It is mainly for distance. Copper is limited to 100 meters before a repeating device (switch) is required.
OG
__________________
I despise when people take random quotes and ascribe them to me - Julius Caesar |
#7 |
in addition Fiber is immune to RF interference. If that factors in.
__________________
. . .Nostalgia used to be so much better . . . |
#8 |
![]() ![]() Join Date: Dec 2018
does that moxa switch support DLR?
#9 |
I don't think any Moxa switch supports DLR, turbo ring etc is a different technology.
__________________
Regards, Patrick G. B.Eng MIET Making the flashy lights flash since the 90's SCADA - Inductive Automation Gold Integrator | PLC | Control Panels | Robotics | Training Connect with Matrix Engineering My son was chewing on an electrical cord, so I had to ground him. He is doing better currently and conducting himself properly. My electrical skills are quite poor, which is a shock to some people ![]() |
#10 |
#11 |
When using fiber cable, you are not locked by the length of Ethernet cables and you do not have to take into account an electrical potential difference that may exist between boards.
VDFs can generate electrical noise and this is not carried around the entire system when using fiber. Long Ethernet cables can also be a problem in terms of electrical noise, so always use as short cables as possible and always shielded cables. DLR is only useful if you have several IO modules where you get a ring connection at the IO level. In the solution I have proposed, there is a ring connection between switches, so there is a high uptime on the connection to these. The Moxa switch Supports EtherNet/IP and Modbus TCP protocols for device management and monitoring. |
#12 | ||
Quote:
Quote:
#13 |
DLR is AB's protocol to monitor network health and if setup properly will tell you when a node is not responding. you can include NON-DLR components but they cant be back to back.
you need to make the decision if you are going fiber or ethernet because that will dictate component selection. i used these on a project, they do media conversion and support DLR https://hirschmann.com/en/Hirschmann...s_/index.phtml https://literature.rockwellautomatio...t007_-en-p.pdf Last edited by mobil1syn; January 24th, 2023 at 06:55 PM. |
#14 |
Personally, I want to go fiber. Many Reasons - no cross talk, electrical isolation, longer length, etc.
My concern is that in case of damaged fiber cable, maintenance will not know what to do -> downtime. With copper, just replace it. Has anybody worked with the https://paigedatacom.com/gamechanger? Claims to have limit of 250m, instead of regular Ethernet cable - 100m. I'm considering Stratix 5700 switches. They are quite versatile. Also have combo ports, which I can configure for copper or fiber. Has anybody had issues with these? |
#15 |
if the process is of high importance, pull spare fiber lines during construction and/or have spare cables made and stored in the event something is damaged.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
More questions about RSemulator, PLC network, and career path... | timcph2008 | LIVE PLC Questions And Answers | 0 | March 8th, 2018 01:04 PM |
Wireless PLC Network | allenz2123 | LIVE PLC Questions And Answers | 6 | October 30th, 2014 12:23 AM |
Rs logix 5000 | varunmahendran91 | LIVE PLC Questions And Answers | 4 | October 6th, 2014 03:26 PM |
Plc suggestion | aec | LIVE PLC Questions And Answers | 36 | January 2nd, 2012 02:56 AM |
