PlantPAx Flow Control Valve Setup
zackscriven
Sep 2017
Rancho Cucamonga
Hi! I am programming a control system using Control Logix and we have standardized on the PlantPAx Library for graphics and control.
I have a Flow Control Valve that is going to be controlled with a PID loop.
The Flow signal will be the PID PV
The Valve Position will be the PID CV
What am I to do with the other Valve Signals I have? Fully opened, fully closed, ready, and fault?
I can't use the P_ValveC because the analog position control is used in the PID. Should I use a P_ValveHO?
Any help is much appreciated. Thanks in advance.
-Zack
-Zack
You should be able to tie the P_PIDE.Out_CV to the P_ValveC.OSet_CV (or .PSet_CV) and then you can tie your LS into Inp_OpenLS/Inp_ClosedLS.
You valve position output ties to P_ValveC.Out_CV
P_ValveHO is for a hand operated binary valve.
Hello All We have 3rd party vendors that run on older versions of PLC (Plc2.0) while we run the main system using plantpax and PLC 3.5-10. Plantpx...
50
Dear Members, Hello, we are working on a project and facing an issue with the plantpax 5 PMTR library, we have a bidirectional motor, which has 2...
185
The PMTR has a timeout parameter for run feedback during a start, but once the motor has been running for a while and loses that run feedback (to...
195
Hello, I am upgrading some custom AOI's for a customer that was using plantpax 3.5 they are moving to Pax v5. In their old AOI's they were...
499
Hello, I am trying to design a new system using the latest and greatest in PlantPAX but also wanting to use STO over ethernet for vfd's. The...
669
