AB DeviceNet problem
angi
Jan 2010
us
361
Hi guys
I just got a devicenet problem from my machine on the floor:
I could go on line with 1784-PCIDS to check all ADNs, but when I try to connect with different subnet,1734-ADN adapter, it would show me all devices in the subnet were missing. what is this problem, and how to fix it?
I think that what you are describing is the inability to browse to a POINTbus through the 1734-ADN Adapter.
Remember that you typically have two DeviceNet configuration files when you deal with a 1734-ADN; the configuration where the 1734-ADN is an Adapter to the main controller's Scanner, and the configuration where the 1734-ADN is the Scanner for multiple POINT I/O modules.
If the POINTBus is damaged, or there is a power problem, certainly that might prevent you from browsing through it.
If you don't have the proper EDS file registered for the 1734-ADN, then RSLinx won't show you the [+] symbols to allow you to browse down through the 1734-ADN. Download and register the EDS files for the model and firmware of 1734-ADN you have installed.
What exactly is the problem being reported ? Are there any diagnostic LEDs that aren't solid green ? Any scrolling error messages on scanner devices ?
Thanks Ken
the error message come out when I try to go online with ADN is:
Device 00 had experenced a identity communication error. the LED on the adapter all ok.
Hi all, I really need some advice for establishing communication between 1770 KFD with DeviceNet and my laptop. 1. What cable should I use to...
2,434
I would like to request everyone's help so i can enjoy the holiday seasons. Our PLC for our Ship Unloader (Allen Bradley) suddenly lost all...
1,678
I have an older machine controlled by AB 5/05 processor with a DeviceNet card in slot 9 that communicates with a remote I/O rack. An input card...
2,334
Hi All! I added a combination I/O module 1794 IE4 XOE2/B to the end of 1794 RIO devicenet node. In RSNetworx for Devicenet V11 (CPR9) for some...
5,159
We have a 1769-sdn scanner that is giving me a lot of problems. Last week node #2 ( 1738-adn12) had a short in the card. I replaced the card...
1,369
