Hello!
I am using guardlogix first time and i have some queries.There are 2 areas Main program and safety task.So, Main area is just like controllogix area.
What i have understand that safety task area is actually in case of failure that safety task shall be priority task for partner.
Off course it will be keep running in normal operation.Right?
Second SIL3 system should have safety task to prevent any failure.
But now come to my system.There is no redundancy at all for both PLC(1756-L81ES) and IOs(Point IOs).
I have only DIs and DOs where DIs act as Causes and DOs as Effects.I have developed everything in the safety task area from IOs mapping to Cause and effect.
My question is it ok to keep everything in safety task?Or I should keep IO mapping in standard/Main area and create cause and effect in safety task?
