Hello everyone,
I have a problem with TwinCAT 3. When I want to rename a variable, the name is changed only at this position, but not in other places where that variable is used in the software. I have already checked in the TwinCAT options (Tools > Options) under category TwinCAT > PLC Environment > Refactoring but everything is already turned on. Also in the Beckhoff documentation is written that when I select variable under refactoring there is rename option, but in my case, there is no rename (See in the picture).
Thank you in advance,
Best regards, Mateja
