clean way to make the red error light go out
ganutenator
May 2002
kansas
1,440
I have a program and I don't want to have 3 programs.
Depending on the options, not all customers will use all 4 analog inputs.
I would like to have just one program and leave the 4 analog input channels configured.
But i don't want the red error light on the analog card to be on if they aren't using all 4.
can i just put a resistor on the input?
tech support said this wouldn't work.
I can't see why it wouldn't.
What analog input level? It would probably be useful to tell people what PLC and input you have.
Just configure your inputs to be 0-20mA and do the 4mA detection in software.
you retarded. but retarded cool
Thank you. Most people don't appreciate the effort that I put into acting stupid, but remaining employable.
Of course, the snappy banter was just a distraction while we wait for you to let us know about your hardware...
As for your own suggestion, I can't see why a resistor wouldn't work. But then again, a spec sheet can be very informative...
how are the Inputs configured?
the Cards can according to Google:
Voltage ±10V, ±5V, 0 to 10V, 0 to 5V and 1 to 5V
Current 0...20mA, 4…20mA and ±20mA
if your are using 4-20 mA, then the best way is to configure it to 0-20mA (like Saffa already said) and enable it by the HMI/Software.
Yes, you can put a resistor between 24V and your input. For example 24V/10mA = 2400 Ohms, and the AIN- to GND.
If you have a current sensor you can, depending on how you have your logic, put both inputs in series.
Both will read the same value and avoid the LED light. The issue is really making sure that your logic disregards the 4th input if it's not supposed to be used.
Curious if anybody has any documentation or input on what this exactly does . Many times when I have a problem it is one of the first things tech...
2,313
Hi All, I was assigned a project to help to reduce cup scrap during a clean out process. The cups travel on four conveyors prior entering robot...
21
5,196
Hi all, The plant I work in seems to have a lot of contamination that affects our Ethernet connectors on all of our control panels. We are...
1,595
I've probably been to a dozen different tube/hose, and wire/cable extrusion plants and they all have in common a haphazard arrangement of...
3,009
When cutting square holes in an enclosure to mount an HMI, what method do YOU use? I've tried Jigsaw, angle grinder with abrasive cut-off disc...
8,107
