Code Meter license issue after Factory Talk Activation upgrade
Stonent
Jan 2015
Texas
We're being required to upgrade all of our Factory Talk Activation installs to 4.01 to address a security vulnerability that was disclosed by Rockwell Automation. We had one that was upgraded from 3.6 to 4.01 that seemed ok, but the following day the equipment wasn't working because a program that I was formerly unfamiliar with called Code Meter kept failing its license check with the new Factory Talk Activation software. In order to restore functionality, we had to do a system restore on the associated PC and then the Code Meter was working again.
Since I'm on the IT side of this update, I'm not familiar with some of the applications that are used on some of the equipment. This system was a pre-packaged deal set up by the vendor.
Other than that, all of the other systems we've upgraded seemed fine. (That didn't have Code Meter)
i am trying to develop trend object using parameter file and VBA code i have parameter file as #1 = text #2= text #3= min range #4= max range #5=...
1,064
1,453
Hi All, I'm working with 12 or so global objects I created, that are temperature displays (basic vertical gauge). Each has several parameters...
2,846
hello, I'm a student and for my final grade I have to repare a sepro robot. the only problem I have for now is that i have an error code 3...
35
I received an email from a student with the following code attached. This is supposed to control a floodgate system, and supposed to be written...
23
778
