Servo Motor
this need SINAMICS series for servo motor
as micromster 440 is designed for closed loop vector control for
induction motor have encoder feedback
so servo motor dynamics and motor data identification need servo drive not closed loop vector Technics
That's also a DriveCliq motor
Motor type
1FK7
Synchronous motor
Motor size
101
Shaft height 100
Code No.
Compact (Generation 1)
Cooling type
A
Natural cooling
Rated speed
F
3000 rpm
DC link voltage
600 V
Type of construction
IMB5 mit DQ-Schnittstelle
Connection system
Connector rotatable
Encoder system
D
Incremental encoder 22 bits with 11 bits communtation position, with DRIVE-CLiQ
Mechanical options
G
Keyless shaft, radial eccentricity tolerance N, without holding brake
Protection class/Coating
IP65 and additional IP67 drive end flange, with paint finish (standard: anthracite RAL 7016)
Contact your Siemens rep for an S120/S110 drive and cables
Hi all, New here and new all round to PLC`s. We have a servo drive that runs a cross travel beam backwards and forwards. I am having trouble with...
190
My servo motor instruction is not being executed on the gx works 3 even after the positioning parameters have been set
120
Hi All. I am setting up an Omron 1S Servo Motor to drive a conveyor. It goes forward 200mm, pauses and repeats until it is stopped. However...
741
Hi all, I am having a problem with my servo motor and I'm absolutely stuck as to why it wont run. Without any gearbox or any load attached to...
3,674
We are currently experiencing a fault on 1 of the 3 stepper motors, keying mismatch fault. The stepper motor is SMD23E2-240A-M12S. We bought the...
1,353
