RSLogix 500 PLC sample code for 4-Loop PID blend controller
welday007
May 2003
Is there any sample PLC code or code for sale that would control a
constant ratio of four ingredients being mixed together? The code
will pull four percentages from a recipe list, and during ramp up,
master rate, ramp down, and hold rate, keep the percentage of
ingredients constant. PID control has analog outputs to control
valves and pulsed inputs from flowmeters. Similar code for other PLCs
would be acceptable, but Allen Bradley RSLogix 500 for MicroLogix 1500
PLC is preferred.
PID Ratio Control
the Instruction Set Reference Manual for the PLC-5 family includes something which might help -
http://www.ab.com/manuals/cp/178561.pdf
look at “Ratio Control” on Adobe page 226 of 372 - or book page 14-38
the basic technique shown there may help get you on your way - and no, I don’t know why this material wasn’t included in the SLC Instruction Set Reference Manual -
hint: in the sample Multiplication rung, “Destination N7:52” is the Setpoint of the second PID -
Interested in PID batch recipie
welday007 I am working on something Very similar to what you were talking about I'm new to plc's I am working on a Biodiesel line where i need to control Methanol and Sodium methylate mixing into 2 reactors with feedstock oil and i want to reference a Ingrediants based on a Tritration table of the oil being sampled and have the flow adjusted accordingly dependat on what i enter for the Tritation value also I have two pid loops to control independant of flow a static mix temperature in the reactors if you find it possible i'd like to swap some rslogix code so i have something to base my recipe info on or speake with you furthur on how yours is coming thanks in advance Billy.
Hi there, I'm trying to tune the "completion pressure" for every material on the baler to something possible with three dying cartridges in...
1,072
1.the black switch is master start/stop switch 2. When red pushbutton is pressed once, both motor 1 and 2 should run continuously 3.if you close...
1,752
Hey guys, My colleague recently gave me an Allen Bradley micrologix 1200, I only have rslogix micro starter lite on my laptop. From what I can...
3,026
Hello, I am having some problems and I am wondering if I can get some guidance. I will explain the process I am trying to achieve. I am trying to...
4,103
