Ge 90-30 cpu
chago
Sep 2018
mexico
Hello all
I have a GE CPU IC693CPU331-CE When I try to upload the program show There is no current program logic stored in the PLC , but shows the name of the program , I upload with Versapro 2.4 and Cimplicity , on the emporm Socket there is not chip place on it , some body lift the CPU wile it was turn on will be erased the program ? there is other way to recover the program . unfortunately no Backup program
Any Help Will be Great.
Chago
What is the name of the program? When the PLC loses its memory it reverts to the default name of "HHP".
If someone removed the CPU module from the base plate for more than a few minutes that would cause the RAM memory to be lost because the battery backup for the RAM memory is located on the power supply module.
For that CPU model (CPU331) without an EEPROM, once the program is gone from RAM there is no way to recover it.
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
42
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
90
126
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
107
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
161
