Enabling "touch" on PV Plus panels after a conversion
phuz
Jun 2008
Mohnton, PA
1,044
Let's say you have a converted app from a 1400e. The alarm banner pops up, but none of the buttons are touchable. I don't see any settings that prevent touch. The close display button that was created on the alarm popup doesn't work, but if I create a new close display button right next to it, that one works.
Obviously has something to do with the conversion, but I don't see any settings anywhere within FTView studio to make those buttons respond to touch. The buttons are also linked to F-keys, which do work.
WAG...Can you change the type of PV+ that the software is using? It may think it is key only.
It's been a while with me and FTME so I can't remember where to point you in the software.
HTH
HTH
No, it was already set for PVPlus 7 Performance. I found that if you called the Property Panel by right clicking on the buttons, there is an option for "Touch" which was disabled for those buttons. Not sure why. I wouldn't have expected that option there since it wasn't in the normal properties GUI.
Hello, I'm working on a project using an Allen-Bradley 1769-L30ER v31 and a Panelveiw Plus7 v11. I have an AOI that keeps track of the time a...
151
Hi all, I'm having trouble connecting and running an SEW motor from an Allen Bradley PLC and MOVIFIT FC. I'm using Studio5000 V23 and MOVITOOLS...
911
Hello I am trying to enable Visual Basic for FactoryTalk SE v.10.0. I have a coworker who has it enabled on his v.9.0 but he cannot remember how...
1,965
Hey, I'm used to CompactLogix 5000 controllers and was needing to know the process of forcing on bits and enabling forces on a SLC 500 Allen...
1,959
Greetings All! Preface: I am a complete "fresh out of the womb"-type novice when it comes to PLC programming. I helped get a Logix 500 PLC up and...
17
8,196
