Schneider LMC20 Loses Program
raccjim
Sep 2012
Reading, PA
94
I have a machine which uses a Schneider LMC 20 Motion Controller connected to two drives. My problem is that any time the controller is powered down, the program is lost and must be re-downloaded via the MotionPro software.(annoying) Does anyone know if this is normal or is there a memory problem that I am unaware of? I have not found any indication of a battery in my documentation but the controller has been in service for about 8 years so if there is one I'm sure it needs changing...
Any help is appreciated!
Make sure that you "create boot project" when online with controller
If yes, then may be the time to upgrade to new one.
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
33
74
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
170
Hi Please I have zeilo smart relay #SR2A201BD but I don't have it's programming cable. Can I use any general usb/rs232 converter? Or need...
130
Hello, Recently I was asked to analyze the logic of the air conditioning system in one of our departments. The PLC that controls this system is...
147
