Tia Portal and MP277 Connection problems
Blue Fox
Feb 2013
Basildon
49
Hello all,
I am hoping someone can help me with an issue I am having with a HMI. I am trying to update a HMI using TIA prtal versions 13 and 14 and have the same issues in both. The HMI is a Seimens MP277 10" I never used to have any issues with the screen on TIA portal V12 but having been away from the site for 18 months I have returned and am now having problems.
When I try to download I do a search for the screen and TIA portal finds it no problem but when I then go load it stops with an error saying it couldn't connect to the screen. I have tried a couple of different methods - plugging directly into the screen in the LAN socket, plugging into the Lan router and over WIFI but these all produce the same issue and all worked previously.
Any help would be greatly appreciated as it is probably goin gto be something obvious that I have missed!!
Hello all,
You might need to check which transfer driver to use. The MPs support both PN and Ethernet. Both use the ethernet cable, but it needs to be the same on both sides.
102
Hi guys , I'm new with Allen Bradley, but I have experience with Tia portal (s7 1200 ,s7 1500) I want to convert my project from Tia portal to...
189
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
153
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
302
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
438
