VBA Syntax to Open a Display with paramters in FTView SE
Jul 2007
Kiruna
600
Hi there,
Anyone know the VBA syntax to open a display and pass a parameter file in FTVIew SE?
I can open the Display using Application.ShowDisplay("Display") but cant figure out how pass a parameter.
The original request is a bit old, but to close the loop on it.
Application.ShowDisplay "Display Name", "/PNameOfParameterFile"
Doing this with VBA does allow for some tricks, like
Application.ShowDisplay "Display Name". "/P" & Button1.Tooltip
Where Button1 is part of a Global Object, and Button1 Tooltip field is defined as a Literal String referencing a Global Object Parameter... then you can pass the Parameter File name into the Global Object (via the Parameter), and have the VBA launch a display and use the parameter file referenced.
I have an HMI based on Proficy Ifix 5.5 which contains a header, footer, and main screen. the footer contains a panel of navigating buttons which...
1,361
Hi Guys, Looking for someone well versed in VBA that can either tell me a certain naming convention or point me in the right direction (I'm a...
58
I need to use a TreeView in my FactoryTalk SE project and i found it under "ActiveX Object" > "Microsoft TreeView Control 6.0 (SP4)". Everything...
37
I'm creating an HMI that has a recipe with 288 data point. It has 3 pieces of data for 96 segments. I need help with VBA code to copy all 288...
140
Hi everyone Is it possible to change a button image in FactoryTalk View SE (v13.00) using VBA?
82
