CTUve command not change
Alley Cat
Mar 2017
Austin
I am using Configuator 3 which is essentially a version of Crimson 2 to program a HMI CTVue 306A to talk to FMT from Emerison via a Modbus. I am using the GUI of the HMI to open the solenoid using Gui on the HMI to right to FMT. The values will not let me change them on GUI. They instantaneously go to there default state. Is there a setting on the tag to fix this or am I not suppose to change these values?
Regards
Tech support from says Coil 405 should fire the solenoid. The HMI tells me the valve is on and I can not turn it off with my code.
Regards
Can you open the CTView file in Crimson? If so post it here?
Do you have the tag set up as Read/Write or Write? How are you setting 405 to a 1? Do you set it back to a 0? We really need to see how you are doing this to be able to help you so if you can post the program post some screen shots.
Thanks Bullzi
Hard to see the tag JPEG but can you post the program? It looks just like Crimson 3
How is the PB set up on the page? In the Tag Configuration you have a PLC1 set up. What is that going to?
Try using a 2 state selector switch. I think the toggle may not be writting a 0 to the coil. See the attached pictures.
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
45
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
87
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
133
Hello guys, I am new to this forum and have some problems with my PowerFlex755 EENET frequency inverter. I want to do a point to point...
385
I have an issue with Power Flex 525 during running processing, the VFD stopped suddenly while the PLC and VFD connection ok, VFD does not have any...
125
