Schneider LMC20 Loses Program
raccjim
Sep 2012
Reading, PA
94
I have a machine which uses a Schneider LMC 20 Motion Controller connected to two drives. My problem is that any time the controller is powered down, the program is lost and must be re-downloaded via the MotionPro software.(annoying) Does anyone know if this is normal or is there a memory problem that I am unaware of? I have not found any indication of a battery in my documentation but the controller has been in service for about 8 years so if there is one I'm sure it needs changing...
Any help is appreciated!
Make sure that you "create boot project" when online with controller
If yes, then may be the time to upgrade to new one.
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
36
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
128
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
57
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
103
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
187
