S7-400H Redundant Configration
alijuda
Jan 2013
Iraq
62
Dear Friends
I needs your help , Please Is necessary to copy all S7 Program in both PLC , Master & Slave or only in Rack-0- PLC ?
Best Regards
Ali
Many Thanks fredz0003 , My point as below and attached pic.
Master CPU have "S7-Program & Connections" under their tree
Slave CPU have only "Connections " under their tree
Is that normal for Redundant works
Yes, is normal. Two H cpus form a single station. The PG uses one program only. when you transfer the program will be loaded in both.
Yes it is normal. However @rjua mentioned when you transfer it loads on both CPU's. In my experience when I've downloaded projects to both CPU's you have to download one at a time.
I could be wrong maybe other projects are setup different, but that's just my experience.
Hi all, I'm strugglin with mtbf calculation for my system, that is a siemens sistem H with double central rack and double et200M redundant on...
1,514
Help is needed for Redundant i/o's to use in the program i have Digital input modules in in 2 different ET200 redundant racks Address of one...
3,250
Hi, We have a new S7 400H redundant configuration with CP441 & CP443. The system runs well on Solo mode, but I am unable to get it up on full...
3,424
I'm facing problem in the redundant I/O's and CPU (S7 414H). We are using the Analog Module 6ES7431-0HH00-0AB0, problem is when we connect a...
3,249
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
54
