iant said:
I was looking at the system that Geospark showed - it might be ok for that industry - it looks like if you unplug the USB lead the E/Stop no longer functions is that right?
rpoet said:
That is my understanding as well. I'm trying for something a little more robust.
The manual I attached for the Showstopper, if you read it, states that "
The USB connection is required for using the cue control functionality of the Showstopper,
but is not required for the Emergency Stop system".
iant said:
...I was interested in the details from Geospark.
mainly because the system looks like it is a huge risk...
Ian, perhaps you are basing your above assessment on the thinking that if the USB cable is unplugged, the Emergency Stop is rendered useless?
Either way, I can see your concerns here, and to be honest, I'm not completely sold on it either, as they don't seem to have much details on their website as to which, if any, safety regulations/codes their system conforms to. That's why I mentioned this, and that you'd have to ask them.
iant said:
...I would be worried about the silent readers who may think it is OK.
While we now know that rpoet is looking for a far more advanced system than the likes of Creative Conners can provide, I still want to make it a bit clearer as to how their system works, in case some readers are unsure.
Forget the USB for the moment.
The Showstopper is an Emergency Stop unit which has six 5-pin XLR outputs for connecting to Stagehand units. Each Stagehand unit is a controller for your driven motors, which has an Emergency Stop 5-pin XLR input connector.
Output one on the Showstopper has a switch for selecting whether it is a standard output or a Remote Emergency Stop circuit input. When output one is set to Remote, you can daisy chain Remote Emergency Stop units using XLR leads. Each Remote Emergency Stop unit has a male and female XLR socket to facilitate this. On the last Remote, you connect in on the male socket and you use a terminating XLR plug in the female socket to bridge the end of the circuit.
A 24VDC signal is sent from the Showstopper to each Stagehand unit to enable the Emergency Stop circuit.
Any activation of a Remote, or the Showstopper unit's Emergency Stop, will drop the 24VDC signal to the Stagehand units. This drops out the Stagehand's Emergency Stop contactor, stopping their driven motors dead.
The USB on the Showstopper is for a separate feature of the unit, which allows you to navigate your scene cues via the Spikemark software running on the PC connected via the USB.
The Showstopper has LAST, NEXT, LOAD buttons for the cues.
The Stagehand units are also connected to a PC running Spikemark, but via Ethernet. Spikemark controls the cues for the motors speed and position using encoders and limits which are connected to the Stagehand unit.
If you already have servos, then you can use a Stagehand Mini, which does all of the above, except it does not drive the motors, but merely controls your existing servos.
If you need more than six Stagehands on the Showstopper Emergency Stop system, you can use Showstopper Hubs, which give you a further six Stagehand outputs each.
There is an Emergency Stop contactor in the Stagehand which is held energized by the 24VDC supply from the Showstopper. Upon Emergency Stop, this contactor breaks the 3Phase supply to the Stagehand servo and brake.
All that is well and good and I'm sure works fine, but what I'd be more interested in knowing is...
Does this Emergency Stop system have built in redundancy and self-checking measures?
What SIL level can it achieve?
What PL level can the safety components reach?
What Stop Categories can it accommodate?
Again, questions you would have to ask them.
This is just one company, perhaps there are others?
rpoet,
All that is academic now, as you seem to be a self sufficient outfit who design their own in-house systems.
If companies within the theater automation business are indeed rolling their own safety systems without regard to regulations and codes (I hope not), then it further highlights the need for specific codes for this industry, if they don't already exist?
Applying normal safety system design principles to your proposed specification is, in my opinion, complicated.
As Manglemender pointed out, each new, and unique production should be independently risk assessed. An appropriate level of safety should then be calculated for each of those risk assessments. A safety system design would then need to be done for each one, selecting the appropriate safety rated components and their positions. This would then have to be tested, and documented. Training would then need to be provided to personnel for each safety system as to how it functions.
If using the same safety system again, after being swapped out and back again, you would have to re-test it and document it again. Re-training may be necessary, especially if using a different crew from the last time the safety system was used.
A signage system may also be required to indicate to personnel which safety system is in use.
It is also an iterative process. You may need to further improve certain safety measures if new risks are identified.
Every new production will require this process, if you want to do it correctly.
Observation:
I keep seeing people here on this Forum looking for safety equipment to suit their needs, but never a mention of a risk assessment. It's a requirement, not a luxury.
Finding the safety equipment that will do what
you want is the easier part here. Constantly re-configuring, while maintaining the
required safety levels, is the complicated part.
As I said, I would not like to be designing safety systems within your industry, and I'm a certified machine safety expert (CMSE).
I'll continue to watch this one with interest.
G.
