Crimson 3 Win 7 FAILS w/ any Text Paste
KenO
Mar 2013
Pittsburgh, PA
RedLion Crimson 3.0 in Win 7 FAILS with any text PASTE.o_O
UNinstalled Crimson 3.0 (Build 523.003).
UNinstalled Crimson 2.0.
(Edict-97 is installed in XP under VMWare - not running).
Ran CCleaner - Rebooted PC.
REinstalled Crimson 3.0 (Build 530.002).
Ran Crimson 3.0 and opened NEW blank project.
Any text PASTE in Crimson 3.0 causes failure.
NO other app(Word,Excel,Notepad++,Outlook,...) has problem.
Failure shows in Event viewer as:
Exception code: 0xc0000005
Faulting application path: C:\Program Files\Red Lion Controls\Crimson 3.0\shexe.exe
Does anyone know how to fix this Win7 Crimson 3.0 "text PASTE" FAILURE.
Ken,
I emailed you directly asking but does it still fail if you try pasting with a new Crimson file.
Jeremy
I know that this doesn't help much, but I have tried this on three Windows 7 machines and two XP machines and I don't have a problem. If there is something else you want me to try I'll do what I can.
I brought up Crimson 3.0 and the default Program1. I ran ProcMon and put a filter to show the Crimson 3.0 prcoess shexe.exe. When the cursor is put in the code field ~2000 lines of Win 7 appear in Procman. Then when I Paste into the
code field Crimson 3.0 fails. The last ~200 lines shows some failure, but the things happening are beyound my Ken. I've attached the Procmon file "Logfile B.PML". Maybe someone more versed in Win 7 operations can determine what is dross and what are real error issues.
Newb here, Have a CUD5B000 disp with USB option board. Installed crimson 3. Installed the USB option board. Connected CUD5B000 windows said...
5,267
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
115
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
191
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
107
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
91
