PID pv simulation in PLC
pauly
May 2002
South Wales,U.k
244
Would anybody know how I can simulate the PV of a PID function using the output of the PID itself? I have seen it done before using an integrator function between the PID output and then feeding it back to the input as a PV but for the life of me I can't remember how. I have tried on my PLC simulation with an integrator function but the output of the integrator doesn't move with a change in input. My PLC unfortunately is an ABB AC800m but if anyone has a general idea I can adapt it.
If pauly is using a S7 then it is easy to simulate FOPDT or SOPDT systems.
I do simulations all the time.
There is a file called hotrod.zip in the download misc section of this forum where I simulated Ron Beaufort's hotrod training systems. The problem is that is is written using RS500.
I have a few newer S7-1200 or S7-1500 available now.
65
There has been quite a lot about PID programming & simulation recently & I thought some people might like this idea, it is a bit Heath Robinson...
998
Hello, I have been developing a library of function blocks. One of the developed function blocks is the PID controller. I have created a Simulink...
2,985
Hello, I am learning Honeywell PKS on a PKS R311 virtual machine. I built a PID CM and loaded to the simulation. Does anybody know how to make...
2,194
Hi, I am new to Mitsi and I'm working on a project that will use a few PID loops. I do not have the hardware in the office so I am using the...
3,670
