FTView SE Local Station ActiveX wmpdll.cab missing
joelryan22
Aug 2017
Ohio
Hi everyone,
I've run into an issue using using the embedded windows media player with ActiveX on FTView SE local station. When I test the display in FTView Studio the embedded wmp video displays fine but when I run the program using the client i get the error "Unable to load ActiveX control for display <Screen_5>" and then the error "cause: Windows Media Player: CAB file missing on the server http://localhost/RSViewActiveXControlSetup/wmpdll.cab"
Here is what i have tried so far:
1. using the file wmp.dll i created a cab file called "wmpdll.cab" and place it in the folder c:\users\public\documents\rsviewenterprise\activexcontrolsetup
2. use regvsr32 to add wmp.dll to the registry
Any other ideas for a solution to this issue?
Compare the two .dll files properties and note the difference.
Copy and paste the .dll on the client, into somewhere safe. Delete it from it's origional location. Then paste the .dll from the server into that file location.
I see the issue quite often with the FM20.dll.
Hi everyone,
Hi Joel,
Did you ever find a resolution for this ?
I am having the same problem with FTView v9.0 on Windows 10 - I create a brand new test display then create ActiveX Control with Windows Media Player. It creates and tests just fine but when I close and re-open the display I get the same CAB file missing error as you do.
Tried creating a CAB file in that directory with CABARC as you did but did not work.
If you have a resolution please let me know !
Has anyone ever used Schneider's OPC Factory Server with Rockwell's FTview SE Local station before? I'm using a Schneider 416NHM30042A Modbus Plus...
1,505
Good day all, i have had a look through the manual, i am using Factory talk view se 8.2. I have created a local station application. What is...
1,215
Hi all, My company is building a machine that has a HMI that uses FTview SE Network distributed system. the HMI server and network directory are...
5,745
Is there any way to import local messages? I have over 3,000 and would hate to type each one. What I'm trying to do is look at a DINT plc tag and...
1,739
Hi guys, I'm needing to build a "Local Messages" file for an existing PV+ application. This file will need to contain all the alarm and warning...
2,525
