Connecting a 4-20mA signal to the ML1100 0-10V Analog Input
Blue92
Sep 2019
N/A
27
Just asking for clarification here, but from my research all I need is a 500 ohm resistor across the AI and the common? Heres my schematic.
URL]
I understand a 250 ohm resistor will yield a 1-5v range, but why use one over the 500 ohm? I have a few of both coming to me this week to play with, along with a 4-20mA air pressure sensor.
Got a picture of my schematic up.
That should work. Would need to know what the sensor is to be sure though.
I do have one issue ,the label on the source power supply (+24- -24)
if it is then that's 48v. Most likely it 0- +24 vdc (hopefully)
I'm assuming that the analogue card is set to passive and this is a two wire sensor, then it is correct. if it was a 3 wire sensor then just feed the 24v to the +, ov to -(OV) of the sensor then the out to +in & OV to Com. with 500 ohm resistor across the analogue +in & 0V
Can anyone give me diagram when connecting a conrol valve (with two terminals - 4-20mA) to PLC Analog Output module? Thank you..
5,283
I've got a 1762-IF4 w/ a micrologix 1200 and I'm using a 4-20mA transmitter in order to hook up pH and conductivity to the plc. The transmitter...
2,450
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
29
81
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
88
