Pid Loop Rslogix
Oct 2002
I have a 4-20mA coming from a temperature transmitter. I need to create a PID loop to contol a steam valve. Using RS LOGIX 5/03 processor. I have never used a PID loop before. Does anyone know how to achieve this?
SOR LEQ I:4.0 3277 BST OTE B3:2/0 NXB MOV 0.0 F8:0 BND EOR  SOR GEQ I:4.0 16384 BST OTE B3:2/1 NXB MOV 20.0 F8:0 BND EOR  SOR XIO B3:2/0 XIO B3:2/1 SCP I:4.0 3277.0 16383.0 0.0 20.0 F8:0 EOR  SOR SCP F8:0 0.0 20.0 0.0 16383.0 N7:0 EOR  SOR XIC I:2.0/5 MOV 9.0 F8:1 EOR  SOR XIC I:2.0/5 SCP F8:1 0.0 20.0 0.0 16383.0 N11:2 EOR  SOR XIO B3:2/0 XIO B3:2/1 PID N11:0 N7:0 N7:1 EOR  SOR SCP N7:1 0 16384 6240 31203 O:5.0 EOR
I am using PID instruction in RS Logix 5000 with independent equation. I am confused about its tuning. Please somebody explain under listed...
4,921
I am trying to adjust my PID loop: The process variable is % solids in water. The control Variable is % VFD pump speed. The problem with the...
2,278
I'm new to PLC's and am working on a practice program which includes a PID control for a steam valve used to control the temperature in a tank...
17
21,364
Is there any sample PLC code or code for sale that would control a constant ratio of four ingredients being mixed together? The code will pull...
15,647
Hello, I am attempting to tune a PID loop on a process. The process involves a valve with electronic actuator that has quite a high deadband...
2,161
